Activity Forums Zaxwerks Jigsaw Puzzle
  • Jigsaw Puzzle
    Posted by John Rich on October 6, 2009 at 1:34 am
    I need some help with mapping. I’ve looked at Serge Hamad’s excellent dvd several times and I still can’t get this to work out.
    I posted this earlier https://www.zaxwerks.com/forum/index.html
    I created a a puzzle of four pieces in illustrator and separated them into four separate pieces and imported them into Invigorator Pro. Ok so far.
    Then I imported a picture into a 720×480 PAR 1.2 widescreen comp and sized it to fit the comp window.
    Then I pasted the paths from illustrator onto the picture and made four copies of the layer.
    Then I deleted three different paths from each of the layers so I had outlines of each of the pieces.
    I then precoomposed the layers.
    Then using Serge’s technique I used the precomp as a map and applied it to the front face of the piece in Invigorator.
    Unfortunately, the map is too small. I ‘m not sure how to enlarge the map to exactly fit the front part of the puzzle.
    Any help would be greatly appreciated.
    Thanks in advance.
    John Rich
    Serge Hamad replied 16 years, 10 months ago 2 Members · 4 Replies
  • Serge Hamad
    October 6, 2009 at 2:33 am
    Hi John,
    Basically, you should create different layer map compositions at the same aspect ratio then EACH puzzle piece.
    Best you send me the ae project with the picture and ai file. I will be glad to trouble shoot it for you. (serge at nyc-visual dot com)
    Salut.
    Serge
    Invigorator/Proanimator Training: https://library.creativecow.net/articles/hamad_serge/invig_training.php
  • John Rich
    October 6, 2009 at 4:10 pm
    Serge,
    Thanks for looking at this. I sent you and email with the materials. Let me know if you need more info.
    Thanks again,
    John Rich
    JOHNR
  • John Rich
    October 7, 2009 at 1:41 am
    Serge,
    Thanks for showing me how to do the jigsaw project. I’ll post the final result here. I didn’t realize how powerful a piece of software Invigorator is especially combined with Illustrator.
    Like everything else, it’s all about learning to use it.
    John Rich
    JOHNR
  • Serge Hamad
    October 9, 2009 at 3:59 am
    John you are very welcome!
    Salut,
    Serge
