Activity › Forums › Adobe After Effects › Jeweled skin effect from Twilight
Posted by Sharon Jameson on June 14, 2010 at 7:19 pmDoes anyone have any ideas on how I should approach this effect?
The image of the woman is what we shot. She is wearing glitter make-up to start with the effect.
I would like to get to the look that you see in the two screen shots from the movie.
Any suggestions would be helpful.
Thank you.
Sharon Jameson replied 16 years, 2 months ago 5 Members · 11 Replies -
Chris Wright
June 14, 2010 at 7:41 pmi would use find edges controlled by a selectable alpha mask to get the edges that you want, then apply the glow effect. For the non-edges, use the animation preset bloom or glow controlled by a definable color luma mask.
You can get really nice prism effects by putting a shift r,g,b for each color, setting each to screen, then vignette edges with optics compensation effect.
https://technicolorsoftware.hostzi.com/
Kevin Camp
June 14, 2010 at 8:17 pmyou might be able to use trapcode’s starglow (see examples)… it works like the glow effect (you define the threshold for the glow), but will give you star-filter-like streaks and also allows for more color mapping of the ‘glow’ to create a prism-like color effect (it actually has several prism presets).
you will still probably need to mask out highlight areas around the eyes and jewelry… any areas that give extreme hot spots that you don’t want to effect.
don’t have starglow… here’s an old tutorial on how to create your own starglow-like effect (though it’s still not as good as starglow):
https://www.ayatoweb.com/ae_tips_e/ae12_e.html
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Michael Szalapski
June 14, 2010 at 8:22 pmParticular, as Dave mentioned, can be used to get some great sparkles. However, you could probably do it with CC Particle World if you don’t have Particular.
I don’t know that you would need to do tracking or 3d modeling. As I recall, in the movie the special effect wasn’t too terribly advanced like that.
You would just need to do some rotoscoping to isolate the areas where you want the sparkles to appear. (Although, you might get away with keying her skin color, reversing the alpha, and using that as a matte with some rough roto to clean it up.)From a makeup standpoint, she is not pale enough at all. She looks alive. Vampires are supposed to be very pale/dead. And you could certainly do with some much better glitter makeup too. 🙂
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Michael Szalapski
June 14, 2010 at 8:24 pmAh, yes; Starglow! Use that in conjunction with a particle effect and you will have great success.
– The Great Szalam
Sharon Jameson
June 14, 2010 at 8:56 pmThank you everyone for your wonderful suggestions. There is a lot here to work with.
I am pretty new to AE so I will probably stick to the suggestions that use effects that come with the software at first. I also think I will avoid 3-D at this point. Maybe in a few days I will have more questions if I run into trouble.
By the way, she doesn’t need to look like a vampire for what I am doing – and she already has the glitter make-up on.
Ronald Lanham jr
June 15, 2010 at 5:54 amI duplicated the image layer, created a mask to cover the skin (definitely some rotoscoping involved for video). Then I added Hue/Saturation to bleach out the skin. This effect seems to rely on the highlights in the skin.
The glitter effect comes from a very slightly animated Add Grain effect. Make sure to set it to Monocromatic and set the Blend with Original to Screen.
Next add a Fast Blur.
Then a Glow: 75% Threshold, 1 Radius, 1.5 Intensity. Operation should be set to Add. Animate the Color Phase. Now Precompose the two image layers.
Inside the new Comp, add two Glows, one set to Horizontal, one set to Vertical. This gives you the streaks without blowing out the image. They both should be set to Add and A & B colors. make the colors Yellow and Blue for Glow 1, and Red and Purple for Glow 2. This is as close as I could come to the prismatic effect. There might be a better way but I don’t know.
This might be different with motion video but it seems to come pretty close to the effect you seek.
Check the video.
Sharon Jameson
June 15, 2010 at 3:11 pmWow, thanks for all the details.
I’m curious. You say “Check the video” at the end. I am new to this forum. Is there a video that you created for me to see as an attachment or a link somewhere? If so, how do I view it?
Ronald Lanham jr
June 15, 2010 at 3:28 pmSince this was the first time that I have posted, I am under moderation. I will post the vid as soon as they release it. Sorry.
If worse comes to worse I can post it on YouTube and post the link.
Ronald Lanham jr
June 15, 2010 at 3:35 pmHere is the You Tube link.
https://www.youtube.com/watch?v=5u4SLc0Ies0Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Sharon Jameson
June 15, 2010 at 3:54 pmVery Cool!!!!
That works for me. I will try to replicate using your instructions.
Thank you.
