Activity Forums Adobe Premiere Pro JerkyVideo on timeline on CS4 & Audio was ok
  • JerkyVideo on timeline on CS4 & Audio was ok
    Posted by Pushpanatha De silva on February 14, 2010 at 1:36 pm
    Hi
    I am using Sony XDCAM EX1 for video recording on SXS media card. Recorded materialon SXS media card has played ok on TV including audio Not jerky at all. But when I use CS4, draging from sequence window to Time-line in CS4 and when play on time line, on the monitor, I could see jerky video for few seconds and frozen video all the way thru without affecting the audio. Audio was played well without any problem. I have selected the standards as PAL, HD/HQ 1080/25p in both Sony XD CAM EX1 and in CS4 project settings. I would really appreciate if anyone there could really help me on this. Your help and advice is much appreciated.
    Pushpanath
    Danny Winn replied 16 years, 6 months ago 2 Members · 3 Replies
  • Danny Winn
    February 14, 2010 at 5:51 pm
    I’ve had this happen too with my HD footage, the only thing that worked was to set the the preview quality to “Draft Quality” instead of “Highest Quality”.
    Even at Draft Quality it’s still nice and clear since it’s HD footage.
    Hope this helps.
  • Pushpanatha De silva
    February 14, 2010 at 8:54 pm
    Hi Danny,
    Thx 4 ur input.
    I have changed from “highest” to “Draft” in the monitor..but still samething happens. Pictues movement was there only few seconds and freeze it but Audio continuous to play without any problem.This happens to all the clips I drag from the Sequence window.
    Any other idea, I can try??
    Thx vm
    Pushpa
  • Danny Winn
    February 15, 2010 at 12:46 am
    Hmmm?
    What type of file is it? If it’s an uncommpressed HD file like an .avi that’s most likely the problem. HD files in most cases should usually be an Mpeg 2.
    Another thing that sometimes works is to make a small adjustment to the clip like anti flicker (right click on the clip and select field optionsm then anti flicker). Then you will have to render the clip. After it has rendered see if it plays smoothly.
    If that works, you can make any change you want that would make you render the clip (Doesn’t have to be anti flicker). Rendering seems to do something to make the clip play smoother.
    Let me know.
