Activity › Forums › Sony Cameras › Jerky XDCAM clips on QT 7.5.5
  • Jerky XDCAM clips on QT 7.5.5
    Posted by Hernan Jimenez on December 20, 2008 at 6:52 pm
    Hi everyone,
    I recently upgraded my QT 7.4.5 to 7.5.5 and now my XDCam sequences (exported from FCP “under current settings”) OR raw clips converted to QT through XDCAM converter, look a little jerky when played back full screen on Quicktime. This never happened before. Any ideas? Anybody experiencing the same problem?
    MacBook Pro 2.2 GHz Intel Core 2 Duo / 2GB Memory
    Codec: XDCAM EX 1080 (24p, HQ, 35Mb/s VBR)
    I am monitoring this through my laptop display.
    The file is stored in my external hard drive. (However I have tried storing it directly in my system drive, an additional external drive, through FW400, FW800, USB, always same result)
    I have tried viewing clips that were created BEFORE the upgrade. Same result.
    I downgraded to QT 7.4.5 today via Pacifist and that did the trick. However FCP wouldn t open (it told me it needed QT 7.5.5) – i guess when I first upgraded, something in FCP changed that a downgrade would not see. So now I m back to 7.5.5, same issue.
    Hernan Jimenez replied 17 years, 9 months ago 4 Members · 4 Replies
  • Olof Ekbergh
    December 20, 2008 at 8:51 pm
    FCP 6.0.3 works fine with QT 7.5 and XDcam EX works great with it.
    I did not install latest FCP because it requires QT 7.5.5, and that version has lots of problems.
    Olof Ekbergh
  • Michael Palmer
    December 20, 2008 at 10:24 pm
    I just asked you over on the Apple forum if you are up to date with Pro Apps updates?
    Good Luck
    Michael Palmer
  • Rafael Amador
    December 21, 2008 at 6:06 am
    Hi Hernan,
    I work with a MBP and some ESATA HDs editing EX-1 with FC 6.0.5 with QT 7.5.5 and everything runs really smooth.
    The only think I can recoomend you (to everybody) is a regular maintenance. Repair permissions and clean the directories of all your HDs (starting by the System HD) as often as you can.
    Rafael
    http://www.nagavideo.com
  • Hernan Jimenez
    December 22, 2008 at 5:55 am
    Thanks Rafael,
    I have been trying to do exactly what you recommend. I repaired permissions today yet again. Still no improvement. I guess I’m gonna have to call Apple on Monday, but I worry this might be some sort of XDCAM-codec related problem that they may not be able to help with. Still I’ll give it a shot.
