Activity › Forums › Adobe Premiere Pro › Jerky titles
Jerky titles
Posted by Andrea Locati on December 16, 2016 at 11:18 amI am new to Premiere. I have created a video with still images and rolling titles that don’t seem to move smoothly along.
https://www.youtube.com/watch?v=_eJzj4Z9mIw (25fpm)
I can’t understand what settings I have to change. Can you give me a tip, please?Andrea Locati replied 9 years, 9 months ago 4 Members · 7 Replies -
Joe Barta iv
December 16, 2016 at 2:55 pmIt looks like it might be a frame rate conversion issue, from 23.98 to 29.97, where it is adding frames to your motion causing it stutter.
Joe
Living the SuiteLife!
Stuff for editors http://www.cafepress.com/suitelifehttp://www.facebook.com/pages/SuiteLife/1524456414462851?ref=hl
Jeff Pulera
December 16, 2016 at 2:58 pmHi Andrea,
I see what you mean, even the background motion is jerky. Please post a screen shot of the Export Settings for review.
Also, perhaps try turning of GPU Acceleration once – that can sometimes cause export issues.
Jeff Pulera
Safe Harbor Computers -
Andrea Locati
December 17, 2016 at 12:56 pm -
Jeff Coleman
December 17, 2016 at 2:34 pmI rarely have good luck with horizontal motion in QuickTime movies. But your shots behind the titles that are just zooms don’t seem smooth. What happens when your render the same clip with no titles?
Jeff Pulera
December 19, 2016 at 4:00 pmHi Andrea,
I believe I understand the cause of the problem – your Sequence is Progressive, while the Export is Interlaced (Upper Field First).
Are your source video clips 1080i or 1080p? I see you are using 1440×1080, which suggests maybe the source is HDV tape? That is typically 1080i.
I might also question whether the 29.97 frame rate is correct – which country are you working in? Most countries other than US and Japan use PAL video, while 29.97 suggests an NSTC country.
Please right-click a source clip in the Project Bin and select Properties – what are the specs of the video?
When exporting to H.264, you almost always want to use Progressive rather than Interlaced, because computer displays are not interlaced and do not display 1080i video very well. You want 1080p or 720p files for computer/online viewing.
Thank you
Jeff Pulera
Jeff Pulera
December 19, 2016 at 4:05 pmJust watched your video again, which I had not seen in several days, and noticed that the background is all still images, no video. If you are not using any video, then why the 1440×1080 sequence, with 1920×1080 export? Would be better to use 1920×1080 consistently throughout the process then.
Just seems that there may be multiple workflow issues happening at once, adding to the poor output quality.
Jeff
Andrea Locati
December 20, 2016 at 8:42 pmThanks for the reply, Jeff.
I’ve worked my head around the problem and tried saving using different settings (given that I cannot change the sequence settings, right? and so I’d have to start from scratch).
I finally discovered the Match the sequence settings checkbox, but even allowing for the not optimal 29.5 fps in the sequence, I still have a jerky motion all along. I attach the screenshot of the export dialogue.
