Activity Forums Apple Final Cut Pro Legacy jerky slo motion playback
  • jerky slo motion playback
    Posted by Kim Rowley on October 7, 2005 at 1:32 pm
    I’m not getting smoothe playback with clips to which I’ve applaied a speed change (50%). They apparently play back OK on the computer monitor but when I see them on my external monitor they look choppy. My machine specs are in my tag line. Source material is all digiBeta PAL. Seq settings 10 bit uncompressed. I’ve tried changing the video processing setting within the sequence settings to all 3 choices (Best, fastest, normal) and that doesn’t seem to be helping…. what am I doing wrong?
    Kim
    Dual 2.7 GHz G5, 4GB RAM, ATI Radeon 9650, Xserve RAID, AJA IO, 2 20″ Cinema Display, FCP 5.02, OS X10.4.2
    Kim Rowley replied 20 years, 9 months ago 2 Members · 2 Replies
  • Ryan Servant
    December 8, 2005 at 5:58 pm
    did you ever solve this problem? I am having similar issues
  • Kim Rowley
    December 10, 2005 at 2:43 pm
    What I ended up doing is applying a deinterlace filter on the clip in question and that seemed to help quite a bit. It’s located in the FCP effects folder “video”. I’ve seen other software reccommended for slo-mo, but since applying that filter seemed to clear up the issue I didn’t pursue the extra expense route.
    Hope this helps,
    Kim
    Dual 2.7 GHz G5, 4GB RAM, ATI Radeon 9650, Xserve RAID, AJA IO, 2 20″ Cinema Display, FCP 5.03, OS X10.4.3
