Activity Forums Maxon Cinema 4D Jerky playback of Render
  • Jerky playback of Render
    Posted by Marc Lucas on June 10, 2011 at 10:40 am
    Cinema is set at 25fps my output is a 1280×720 at also 25 fps with square pixels. I exported as a TGA sequence with an alpha and straight alpha channel and the 8 bit Dither is on (must of been the default)
    Anti – Aliasing is ‘best’ and set to animation. I converted the TGA sequence in AE as a QT at 25 fps as RGB+Alpha.
    When played in FCP (after rendering the timeline) I get jerky playback it looks like some frames are not there or the frames rate had been set wrong.
    Thanks for any replies
    Randy Johnson replied 15 years, 3 months ago 2 Members · 1 Reply
  • Randy Johnson
    June 12, 2011 at 10:01 am
    Might be that your files are a little to big for your computer to play back at full res. Try lowering the quility of your timeline.
    If that does not help check your AE project RAM preview see how the playback is there.
    /Randy
