Activity › Forums › Panasonic Cameras › jerky picture
jerky picture
Posted by Will Hommeyer on April 9, 2009 at 4:19 pmI have slowly become a big fan of the HVX 200. However, I’m puzzled by something and I’m hoping someone will have an answer for me. When panning I get these jerks in the picture. It’s as if the pan handle was bumped. It is especially a problem when I am using the Letus35 Extreme Lens Adapter with prime lenses. Is anyone else having this problem? Any clues on how to avoid it?
Will Hommeyer replied 17 years, 5 months ago 3 Members · 7 Replies -
Shane Ross
April 9, 2009 at 9:38 pmAre you shooting 720p 24P or 24PN?
Shane
Read my blog, Little Frog in High Def -
Will Hommeyer
April 9, 2009 at 10:02 pmYesterday I was doing a test in 720P/30PN with the Letus35 Extreme Lens Adapter and a 50mm lenses. It looked great but if I tried to do any moves it would jerk. I have had this happen occasionally at other times when shooting 24PN or 60P with the standard camera lens, however, it was much worse with the adapter and prime lens setup.
Shane Ross
April 9, 2009 at 10:45 pmI have not used that adapter, so I don’t know what to say. But without the adapter I have not experienced what you have.
Shane
Will Hommeyer
April 9, 2009 at 11:29 pmYes. It was on yesterday during my test. I usually have it on.
Matthew Romanis
April 9, 2009 at 11:40 pmTry turning it off if you are on a tripod. Stabilisers work best and predictably when there is movement in at least 2 axis’. On a tripod you only get movement in one axis most times.
One more thing.
The jerky movement you are seeing, is it when you play back in camera or through a laptop? -
Will Hommeyer
April 10, 2009 at 3:20 pmOkay, I’ll turn off the OIS. I do a lot of handheld work and have just gotten lazy about turning it off. It makes sense that OIS may be trying to stabilize my pan.
FYI, the jerks are definitely there after pulling clips into Final Cut and playing them back. Although, the effect is much worse when viewing in the LCD viewfinder.
Thanks for the help.
