Activity Forums VEGAS Pro Jerky Frame dropping when pan and tilt
  • Jerky Frame dropping when pan and tilt
    Posted by Matt Cook on September 5, 2014 at 9:53 am
    Hi All
    Im needing a little help and I will try to explain myself as best I can.
    So I have several bits of footage from a wedding that get choppy/jerky when ever I move the camera significantly, for instance when tilting slowly up the wedding cake and also when zooming in on a jpeg. its like its skipping a frame and makes everything look jerky.
    I can see it in vegas but at the time thought it was just the preview lagging a little, but it has also come out in the render. I tried moveing the original copy from my old drive to my system ssd drive but this didnt help.
    The footage is AVCHD 1080/25p
    system spec is
    i1-4770K @3.5ghz
    16 gb ram
    Radion 6850 hd
    Any ideas guys
    Matt
    Dave Osbun replied 11 years, 12 months ago 3 Members · 2 Replies
  • Bob Peterson
    September 5, 2014 at 3:54 pm
    Some cameras do not perform well when doing things like panning. Try panning verrryy slowly and see if that reduces the problem.
  • Dave Osbun
    September 5, 2014 at 5:00 pm
    Is your camera’s sensor a CMOS sensor? Except for the expensive cameras you usually have to pan slowly with modern lower-end CMOS equipped cameras. On my sub-$2000 Sony AVCHD camera I obtain below-quality video on fast moving subjects or quick pans.
    Dave
