Activity Forums Adobe After Effects Expressions JavaScript Addtext() – How do I add a \n (“carriage return”) it the source text?
  • JavaScript Addtext() – How do I add a \n (“carriage return”) it the source text?
    Posted by Michael Powers on August 23, 2005 at 2:23 pm
    eg:
    activeItem.layers.addText(“Select Camera Go to: \n Layers>Transform>Auto-Orient Turn off”);
    “\t” seems to work for tabbing.
    Also, is there a way to access the auto-orient property via javascript?
    Thnx
    Mathew Kaustinen replied 21 years, 1 month ago 4 Members · 7 Replies
  • 7 Replies
  • Filip Vandueren
    August 23, 2005 at 2:30 pm
    Maybe \r will work instead of \n, not sure though.
    Judging by the documentation, Auto-orient seems to be a feature they forgot to implementy in the Object-Model.
    You might want to try adding an expression that mimics the Auto-orient behaviour.
  • Dan Ebberts
    August 23, 2005 at 2:33 pm
    I think “\r” is what you want.
    As far as I know, auto orient is not accessable to scripts.
    Dan
  • Michael Powers
    August 23, 2005 at 2:40 pm
    Thnx for the quick responses!
    I wrote a scene exporter from 3dsMax to After Effects. Right now it just writes a jsx script and then imports the entire scene via the run command: Camera, Lights, Planes, helper objects and mimics several primitives with various layers and effects(cylinder and sphere).
    I have two questions:
    1. Do you think there is any interest for a plug-in like this.
    2. Where do I find some SDK documentation on the .aec file format (I believe the Cinema4D exporter uses this format)?
    Thnx
  • Michael Powers
    August 24, 2005 at 2:55 pm
    I guess noone thinks a plug-in like this would be useful???
  • Filip Vandueren
    August 24, 2005 at 3:02 pm
    You might want to check in the Max forum, many guys over here work on macs and many use Cinema4D.
    I’m one of them 😎 , but I think that your project would be very useful for Max-users.
    Also, the Max / After Effects readers in this forum, porbably haven’t read this post, since it is not at all obvious from the thread-title that it’s a discussion about importing 3dsMax scene files…
  • Michael Powers
    August 24, 2005 at 3:05 pm
    excellent point! I started working on this last year, but put it aside due to work load. Then at NAB I saw Cinema4D’s excellent impimentation of it. AE’s RPF import also leaves alot of valuable channels out as well as Camera FOV (wow that is a problem :)).
  • Mathew Kaustinen
    August 25, 2005 at 11:04 am
    Mpowers,
    Can’t seem to be able to pull up your user details. Please contact me at matt@boomerlabs.com when you have an opportunity.
    Mathew Kaustinen
    Boomer Labs
