Activity › Forums › Blackmagic Design › Jan 31-2012 FCP X update – broadcast monitoring via 3rd party cards/devices
  • Martin Smith
    February 1, 2012 at 5:19 pm
    You have to set the video output resolution from the OS X system Preference Black Magic application.
    If you monitor audio through BM device you have to set the ouput to blackmagic device in the sound preference of OS X as well.
    Let me know how it goes for you, it’s working “ok” here but of course this is beta so no complaining. The biggest issue for me is after playback from the timeline the screen is always black, it doesn’t stop on the frame you stop or pause. You have to fiddle around with the scrubber or click on different clips to make the image come back.
    Playback feels steady.
  • Dave Bergan
    February 1, 2012 at 5:31 pm
    I checked System Prefs before posting, and it does say Desktop Video 9.2, but under the BM app in System Prefs, I don’t have any resolution choices.
  • Tangier Clarke
    February 1, 2012 at 5:51 pm
    Yep, that did the trick. A little cumbersome to have to switch it in system prefs, but it’s a start.
    Now if I could only figure out a way to get my edit out in a format my ProTools guy can use (a la OMF)…
    I can dream can’t I!
    Tangier
  • Martin Smith
    February 1, 2012 at 5:52 pm
    If you have 9.2 beta installed your BM system preference app will show this from the settings tab. It should have a mention of FCP X under the “Set Default Video Standard as:” dropdown.
    Just change the “Set Default Video Standard as:” to whatever you use for editing.
  • Dave Bergan
    February 1, 2012 at 5:57 pm
    Surely it’s that I have an Intensity Pro. I don’t have all those options, including Set default video standard.
  • Martin Smith
    February 1, 2012 at 5:59 pm
    To export to Protools check this app. It’s free.
    https://www.automaticduck.com/products/pefcp/
  • Fabio Cormack
    February 1, 2012 at 7:42 pm
    Still no image here. I can send the audio to the SDI monitor from FCPX, but no image.
    I tried different resolutions from the BM preferences panel (set the video standard as) but no video out yet.
    Any ideas please?
    thank you
    Fabio Cormack
    Davinci 8 – Tangent Wave – Decklink HD Extreme 3D+
    Final Cut Suite
    Adobe CS5.5 Suite
    Rio de Janeiro – Brazil
  • Robin
    February 12, 2012 at 4:23 pm
    how were you able to get the audio out?
  • Martin Smith
    February 13, 2012 at 6:00 pm
    Yes,
    You have to set the audio from the apple system preference / sound.
    Set output device to “blackmagic design…”
    thanks,
    RJ
Page 2 of 2
