Activity Forums Adobe After Effects jamming for sundance- need to create slo mo blur
  • jamming for sundance- need to create slo mo blur
    Posted by Raine Parrish on September 11, 2006 at 7:35 pm
    Hello,
    I need to create a slo mo blur effect on a clip- as if I’ve stopped down to about 8 fps. Does anyone know how to do this? Actually, is it possible?
    PC- 6.5 pro
    Thanks much
    rp
    Raine Parrish replied 20 years ago 3 Members · 3 Replies
  • Sanspoof
    September 11, 2006 at 8:13 pm
    Time stretch and then frame blending???
    You can time stretch a clip however much you want, and then by turning on frame blending it will smooth together. And depending how much you time stretched the clip, the more blurry the effect frame blending has when it smoothes it all down… I believe.
    Timestretch can be found in Layer>timestretch… or on your timeline by adding the duration panel and then clicking on the clip length to bring up the timestretch window.
    Frame blending in uneder the switches section of your timeline; check the box. Note: the bigger frame blending button next to motion blur and soloing is for preview of layers you’ve already checked frame blending for; so you can basically preview the frame blending when you hit num0.
    Or if you actually want an 8fps jerkiness you could precompose your footage and then for the precomp layer press ctrl+k and set the frame rate to 8 (correct me if I’m wrong).
    peace,
    Michael
  • Cal Johnson
    September 11, 2006 at 10:07 pm
    You can slow the clip down by altering the duration or stretch settings (open up the duration/stretch column in the timeline window). You could then add a blur effect to the clip. If you need to you could can select just one direction to the blur, such as horizontal. You could also add the effect twice, for instance adding a high amount of horizontal blur, and then a litte vertical blur as well.
  • Raine Parrish
    September 12, 2006 at 4:51 pm
    Thank you guys- I’ll give it a go!
