Activity Forums Maxon Cinema 4D Jaggy Final Render
  • Jaggy Final Render
    Posted by Richard Windsor on February 20, 2014 at 5:34 pm
    I am having an issue with a bit of text. When I do a preview render all is fine the text is sharp and the lines are ok. But I render the whole movie out and one letter in the text becomes jaggy. I am using the Physical renderer. Can’t figure out why this is happening. I am watching the video at actual size so its not that.
    The pic I posted got horribly compressed so its hard to tell what I am talking about. The letter V on the left image is smooth while the one on the right gets very jaggy.
    Richard Windsor replied 12 years, 6 months ago 2 Members · 2 Replies
  • Joey Trimmer
    February 27, 2014 at 12:46 am
    Have you tried adjusting your sampling quality under Physical in your render settings? Maybe try upping that and if that doesn’t work I’d also adjust anti-aliasing settings. Hope that helps!
  • Richard Windsor
    February 27, 2014 at 2:00 pm
    I tried a lot of things but the only thing that worked was to render it out as a Tiff sequence instead of as a a quicktime. Not sure why that worked but I will take it lol.
