Activity Forums VEGAS Pro jaggy edges
  • jaggy edges
    Posted by Fran Cox on November 21, 2008 at 3:54 am
    Hope someone can help. I have a Sony HDR – SR11, Vegas Pro 8b & now 8c. The system is an AMD dual core 2009 Mhz, 3 gb ram, plenty of HDD space on SATA11 drives, & Windows XP pro.
    I am getting jaggy edges on moving objects when I crop the video. I have tried without cropping & no problem, no problems with anything else that I can see. Same problem with 8b & 8c versions.
    I have adjusted the template settings in the Project Properties, with no success. I have the settings on HDV 1080-50i(1440×1080, fps) at the moment but I have tried numerous others. I have trialled rendering to see if that made it better or worse but that didn’t work either. The field order is upper field first. pixel format is 8-bit.
    I have just used the same clips with PAL DV Widescreen(720×576, 25fps)settings, & cropped down about 50% to really test it and have got the same jaggy edges.
    Would appreciate some help
    Fran
    Fran Cox replied 17 years, 9 months ago 2 Members · 2 Replies
  • Charles Avanti
    November 21, 2008 at 7:08 pm
    I just purchased a Grass Valley, the ADVC110 a fews weeks ago from Firewire-1394.com for $219.
    https://www.firewire-1394.com/canopus-advc-110.htm
    Charlie
  • Fran Cox
    November 24, 2008 at 7:27 am
    Thanks folks for the answers,
    Just after I posted my questions I realised the problem was settings.
    For some unknown reason I completely ignored the Deinterlace method settings. So it was set on none, set it on Blend & hey presto, no jaggy edges. Only time they happen now is when the preview setting is very low quality. So was not a Vegas fault it was the operator.
    Fran
