Activity › Forums › Adobe After Effects › jaggies along alpha edges
Posted by Joe Feng on December 1, 2005 at 10:59 pmWhen an AE animation is imported into Avid, the edges of the alpha channel appear jagged. I’ve read about others having similar problems, but haven’t yet found a tried and true solution.
Any help is much appreciated!
Rambobaby replied 20 years, 9 months ago 5 Members · 10 Replies -
Ben Insler
December 2, 2005 at 5:29 amI have no experience with the AVID, but my first guess is a premultiplies vs. matte alpha interpretation issue. Maybe AVID is expecting one and you’re outputting from AE with the other?
What file type are you rendering out to?
-Ben
Ben Insler
Editor
Telemark Films -
Steve Roberts
December 2, 2005 at 2:47 pmAvid likes images with straight alpha.
Technically, the RGB is straight or premultiplied, but everybody calls it “straight vs. premultiplied alpha”. 🙂
SR
Joe Feng
December 2, 2005 at 2:50 pmI’m rendering the alpha as premultiplied, because when rendered as straight, the result looked like Devil himself…and was totally unacceptable.
The files are uncompressed QTs.
Steve Roberts
December 2, 2005 at 2:57 pmDid you try importing that into Avid?
The result will look like trash until it’s imported into an app that recognizes it. Then it will look fine. 🙂
Steve
Joe Feng
December 2, 2005 at 3:31 pmYeah, that’s what I was hoping too. But the importing didn’t make it look any different.
Don Days
December 2, 2005 at 5:07 pmAre you taking them into the Avid uncompressed? Usually if I’m taking in something with an Alpha I’ll try to keep it uncompressed on the import or at least 2:1.
Joe Feng
December 2, 2005 at 5:13 pmI’m taking them in uncompressed.
Should I be using a different codec other than uncompressed out of AE? I’ve also tried animation and Avid Meridian Uncompressed. Both had similar results. -
Don Days
December 2, 2005 at 5:52 pmNot sure on what you are using for elements in your graphic but if you are using any video elements or pre-rendered animations, make sure your footage is interpreted correctly in AE (make sure your fields are separated). Can you post any stills of the problem?
Joe Feng
December 2, 2005 at 5:59 pmAll the elements are exported from either Illustrator or Photoshop, no videos or prerenders…What’s the best way to post stills up here? Thanks.
Rambobaby
December 3, 2005 at 11:00 pmHere is the text straight from After Effects help files:
After Effects 6.5 lets you output to the OMF (Open Media Framework Interchange) format to generate Avid media essence files. Each OMF codec has a fixed frame size and frame rate, depending on the output resolution you choose. The OMF file format doesn’t support audio, so any audio tracks aren’t converted, but you can output audio tracks separately, if desired.
Note: You can also import OMF files. (See “Importing OMF files (6.5)” on page 84.)
To output a composition to OMF:
1. In the Render Queue window, click the Output Module template name to launch the Output Module Settings dialog box.
2. From the Format drop-down box, select OMF.
3. Click Format Options. Choose a format (NTSC or PAL), AVR (Avid Video Resolution), and OMF version.
Note: OMFI version 1.0 is supported for backward compatibility with older Avid systems.
