Activity Forums Adobe After Effects jaggied edges PSD with corner pin effect
  • jaggied edges PSD with corner pin effect
    Posted by Alan Pover on August 20, 2010 at 2:03 pm
    Hello, does anyone know the reason why the psd has jaggied edges after I applied corner pin effect to it.
    Does it have anything to do with rastarise or pixel aspect ratio
    Alan Pover replied 16 years ago 3 Members · 5 Replies
  • Karl-jason Mawdsley
    August 20, 2010 at 3:49 pm
    Do you have Adaptive Resolution enabled? What res is your PSD?
    KJ Mawdsley
    Editor/Mograph Designer
  • Alan Pover
    August 22, 2010 at 6:27 pm
    No, I didn’t have adaptive resolution turn on. It’s not just in preview, I can see the jaggied edge in the rendered file as well. The resolution of the psd is 900 x 300 px, 72 dpi. It seems to me that it has something to do with the size of the corner pin. I don’t see the jaggied edge if my corner pin area is big, say a quarter of the size of SD. But it’s very visible when it is small, about 90 x 30 px is this case. That’s something I don’t understand.
    August 24, 2010 at 8:45 am
    Sorry about the late reply – I had my notification turned off by accident.
    The corner pin isn’t really designed to crush something that small as I understand it. If you want something that small, I’d resize it in photoshop first and then bring it in to AE.
    Again, sorry about the late reply. Hope this helps.
    KJ Mawdsley
  • David Johnson
    August 24, 2010 at 11:30 am
    I agree with KJ, but if you can’t resize the image in PS for some reason, you can apply AE’s alpha blur after the corner pin (might need to apply a small edge choke first).
  • Alan Pover
    August 30, 2010 at 10:34 am
    Thank you everyone! I will try to resize the psd beforehand. I didn’t do that because I thought it’s better to have a higher resolution psd, turns out it isn’t better.
