Activity Forums Adobe After Effects Jagged vector (dv)
  • Jagged vector (dv)
    Posted by Matt King on January 14, 2009 at 9:37 am
    I have a simple comp (720×576 non-Sq 16:9 pal) with a Vector shape on one side and text on the other and a light washing over them.
    The vector is on continually rasterize etc.
    My Problem: when i render it out to Qt using Animation it looks/plays fine, sharp and clean, but it is going in to Pal Dv edit and thats the problem, the vector shape when rendered in FCP is jagged on the vertical (like fields) but it is not a field issue i have tried rendering odd/even and non fields. when i render straight to Pal dv i get the same problem.
    Also the Text is not having the same problem
    Do i need to do something to the vector or the output.
    cheers
    Matt King replied 17 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
