Activity Forums Adobe Premiere Pro Jagged Titles
  • Jagged Titles
    Posted by Jason on May 31, 2005 at 4:55 am
    Hey guys,
    Just wondering if anyone can help with the following problem.
    I am doing titles in PPro’s titler and everything is fine if it is just a straight title on a background that requires no rendering. ButI have the titles layed over a background still image, which has TGA sequences from AE flowing over it. When the title sequence renders out, I am getting a slight ‘greenish’ out line on some of the titles.
    I have tried creating titles in photoshop and still have the same problem. Also, I have rendered out the background with the after effects layers before putting the titles on. Although this seems to work….its not really useful when I want to have layers going over the top of the titles. So the problem really seems to be when I render out a clip that the titles take a turn for the worse.
    Anyone have any ideas on this?
    I am using a Matrox RTX card and have Optimize Still ‘on’.
    Thanks in advance.
    Mike Velte replied 21 years, 3 months ago 2 Members · 1 Reply
  • Mike Velte
    May 31, 2005 at 11:23 am
    I think if you will search past posts you will find this issue with Matrox and solution…something about applying an effect to the title with no value change, like blur.
    https://www.video2stream.com
