Activity › Forums › Adobe After Effects › Jagged Text on Render
  • Jagged Text on Render
    Posted by Randy Rubin on January 10, 2012 at 3:05 pm
    Hi All,
    I’m a little bit frustrated. I am trying to create a very simple composition. I have a still image, over which I wrote some simple text with no effects. The font type is Avenir LT Com, 55 Roman. The quality setting is at best.
    Both in the composition and when I render a quicktime (tried animation, Avid DNxHD, and PNG) the text is jagged. My footage is 1920×1080 24p. The problem is exacerbated when I bring it into Avid.
    Any help much appreciated.
    Thanks.
    Kevin Camp replied 14 years, 8 months ago 3 Members · 7 Replies
  • 7 Replies
  • Kevin Camp
    January 10, 2012 at 4:04 pm
    when you say the quality was set to best, do you mean the quality switch for the text layer (looks like a diagonal line in the switches panel) or the render setting was set to best? make sure the switch is set to best.
    if that’s not it, does the text look ok with a different font, like arial?
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Randy Rubin
    January 10, 2012 at 4:14 pm
    The switch was set to best. Arial font looks jagged as well.
  • Randy Rubin
    January 10, 2012 at 4:21 pm
    I also just noticed that I have the same problem in another comp. This one is an animation of an illustrator file. Text is jagged. I have continually rasterize on all the layers as well as best quality switch and full resolution.
  • Andrew Donaldson
    January 10, 2012 at 4:45 pm
    Does it still look jagged at 100%?
    Having the composition window at 100% will give a better idea of how it will render out.
  • Kevin Camp
    January 10, 2012 at 5:25 pm
    that could be it, it could also be opengl rendering since the layers are 3d. try turning off opengl acceleration — either lcick the lightning bolt icon at the bottom of the preview window and select ‘adaptive resolution-opengl off’, or go to the preview preferences and uncheck the opengl option.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Randy Rubin
    January 10, 2012 at 6:25 pm
    Thanks for the help, nothing really seems to be working. Here is a grab of the other project. The text is jagged, it doesn’t look sharp – it’s even more pronounced when I switch the font to arial. I also changed the preview in preferences to ‘more accurate’
    Opengl didn’t seem to have an affect on either project.
    On a side note, when I render my final comp should I always turn opengl off, I’ve seen that mentioned on the forum before.
  • Kevin Camp
    January 10, 2012 at 7:36 pm
    the text in that image looks smooth… is the issue that it looks jaggy after import into avid?
    as for the ‘more accurate’ setting that would only be for video preview (previewing on an external/broadcast monitor through hardware like an aja video i/o card), it wouldn’t effect the main ae viewer or rendering.
    as for opengl rendering for the final render, i would pretty much always have that unchecked for final rendering… i almost always keep it unchecked for previews too.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
