Activity Forums Adobe After Effects Jagged text in CS4
  • Jagged text in CS4
    Posted by Göran Thorén on December 8, 2008 at 2:38 pm
    Hi all. Installed CS4 a couple of days ago and I have a huge problem with the text tool.
    Every font looks jagged both in AE and in the rendered file This is a disaster since I do a lot of text work.
    I compared an identical comp in CS3 and a CS4 side by side and in CS3 the text looks fine.
    Any ideas?
    David Bogie replied 17 years, 9 months ago 2 Members · 1 Reply
  • David Bogie
    December 8, 2008 at 4:00 pm
    sorry not to offer a direct answer but over on adobe.com in the support forum for AE, there have been a few threads on the same topic. I even started one (a sudden text jagged issue showed up in CS3 for me) but I have not been able to get back to it. My issue seems to be caused by certain effects applied to text layers. If I use the Text Effect on a standard solid, the text remains clear. This was a weird change, inexplicable. I’ve been doing text for a long time in CS3.
    https://www.adobe.com/support/forums/index.html
    good luck in your search and please post back here if you get some helpful advice.
    bogiesan
