Activity Forums Adobe After Effects Jagged text in after effects . . .
  • Jagged text in after effects . . .
    Posted by Chris Pass on September 22, 2009 at 4:33 pm
    All my text in after effects is jagged and looks like it’s not rasterized, but it is.
    I saw an old post on this, put the solution isn’t fixing my problem (turn off pixel aspect ratio correction).
    I’ve done everything the other post said (turn off PARC, use a square pixel composition) but nothing has corrected these fonts. They look so horrible. Help?
    -Chris Pass
    cpass@me.com
    Miranda Jacobucci replied 9 years, 2 months ago 4 Members · 5 Replies
  • Chris Pass
    September 22, 2009 at 5:19 pm
    Any comp I open, any text layer I create. All fonts are jagged.
  • Chris Pass
    September 22, 2009 at 5:37 pm
    I have. I’m viewing in the highest res I can. It doesn’t matter what type of comp I’m in, the text is still jagged, and it’s for every font I have. I did recently download some new fonts, but I’m not having the same problem in Photoshop or Illustrator.
    -Chris
  • Roland R. kahlenberg
    September 22, 2009 at 7:00 pm
    Ensure that the Comp size is 100%. ANything other than that may result in poor-looking edges on text.
    HTH
    RoRK
    Sell your AEPs with broadcastGEMs’ DVD series of templates. Click here for more
  • Matt Henry
    June 2, 2015 at 1:10 am
    I’m assuming you’re not fighting with this problem after 6 years, but as this thread appears in search results I thought I might be able to help people with similar problems.
    What you’re probably experiencing is a text layer that has had its blending mode set to Dissolve. This can happen if you accidentally mash the wrong keyboard shortcut (shit + plus) which will quietly switch your layer to the next blending mode. The Dissolve blend mode has a very distinctive look of rough, pixelated edges that make you question the composition preview settings unless you’ve made and discovered the true problem in the past.
    -Matt Henry
    @fancymatthenry
  • Miranda Jacobucci
    June 20, 2017 at 6:09 pm
    I had this same problem and found this thread. My issue was that I had Effects on the type. I moved those to a Solid Layer and used a track matte so it appears on my type. Looks great now!
