Activity Forums Adobe After Effects Expressions jagged results with wave warp effect
  • jagged results with wave warp effect
    Posted by Stu Chudy on December 18, 2005 at 4:22 pm
    I am hoping someone can shed some light on this problem I am having. I wish to use the wave warp effect with the sine setting on a pretty high resolution layer (HD 1920×1080). When I crank the wave height settings any higher than 60 (my desired settings would be 120) with the wave width settings up high (900) I get some VERY jagged results. Some strange stairstepping effect that is totally unacceptable. The effect’s anti-aliasing setting is set to high. I thought maybe the quality was on draft, or that it wouldn’t render that way, but it does and there seems to be no way for me to resolve this uglyness. I could not find any other plugin that may do the same thing better (I like having control over the speed in my expressions).
    Is this just a bad limitation of this effect? Is there any suggested workaround or alternatte effect that I can buy to generate smoother sine wave curves?
    Thanks in advance for any help.
    stu
    Stu Chudy replied 20 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
