Activity Forums AJA Video Systems Jagged picture when digitalizing from digibeta with AJA Io LD
  • Jagged picture when digitalizing from digibeta with AJA Io LD
    Posted by David Herdies on February 11, 2009 at 8:13 pm
    I am having problems while digitalizing from a Digibeta recorder. What could be the problem? The workflow is: Digibeta Recorder (DVW-P2000M) SDI-Out –> AJA IoLD SDI In –> Firewire –> Mac Pro Two 3.0GHz Quad-Core Intel Xeon, Mac OSX 10.4.11 with FCP 6.0.3. In FCP I use Capture with SDI 10-Bit PA. In the referende monitor (which is connected diretly from the AJA-box) the picture looks fine, but when I digitalize the material get jagged and speeded up. What might be the problem?!?
    Kind regards,
    David Herdies
    David Herdies replied 17 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
