Activity Forums Adobe After Effects jagged lines
  • jagged lines
    Posted by Paapoopa on March 17, 2006 at 1:09 am
    I am trying to animate some very fine lines in aftereffects, but when i try to go lower then 1 point, it becomes jagged.
    Is 1 point the thinnest that I can go? or is there any other ways to work around it?
    Mark replied 20 years, 5 months ago 3 Members · 2 Replies
  • Sam Moulton
    March 17, 2006 at 1:40 am
    2 pixels is the minimum for video output
    anything else will flicker
  • Mark
    March 17, 2006 at 11:51 am
    The reason behind the flicker is interlace. Television sets will display the 1 pixel line on for one field, then off for the next. Fine lines can be helped by using the reduce interlace filter in AE. This filter adds vertical blur. Thin lines get worse when you move them. The flicker becomes more apparent.
    Mark
