Activity › Forums › Adobe Premiere Pro › Jagged lines
  • Jagged lines
    Posted by Ingemar Berglund on April 28, 2015 at 5:22 am
    Hey
    I’m an editing noob going through clips filmed with an old D7 and see jagged lines everywhere. On horizons, mountain crests etc etc.. Am I right assuming this is some form of aliasing?
    I’m switching cameras (tell myself it’s not too late) to avoid this but I have way too much filmed for this project to throw all I’ve done away.
    Does anyone have any tips on how to at least soften these artifacts a bit in post editing?
    Thanks a lot
    Ingemar
    Ingemar Berglund replied 11 years, 4 months ago 3 Members · 4 Replies
  • Joe Barta iv
    April 28, 2015 at 1:32 pm
    Right click on a clip in the sequence, select Field Options…
    Then select Always Deinterlace
    See if that helps.
    If it is an interlacing problem then you can do a batch of clips at once in a Bin.
    Select the clips you want to deinterlace
    Right click and select Modify > Interpret Footage…
    In the pop up box under Field Order select Conform to:
    Select No Fields (Progressive Scan)
    Joe
    Living the SuiteLife!
    Stuff for editors http://www.cafepress.com/suitelife
    http://www.facebook.com/pages/SuiteLife/1524456414462851?ref=hl
  • Ingemar Berglund
    May 2, 2015 at 9:48 am
    Hey!
    Thanks a lot for your suggestion!
    I tried this on a couple of clips and nothing happened.
    Since the problem is there even before importing them to premiere, the problem might be something else?
    Ingemar
  • Ann Bens
    May 3, 2015 at 10:36 am
    Make sure the sequence setting matches the footage.
    If its interlaced footage make the timeline interlaced.
    Adobe Certified Expert Premiere Pro CC
    Adobe Community Professional
  • Ingemar Berglund
    May 4, 2015 at 3:35 pm
    Hey!
    How do I know if the footage is interlaced?
    I assumed these are dslr-artifacts (like aliasing, moire etc)
