Activity Forums Apple Final Cut Pro Legacy Jagged graphic in Canvas/Timeline
  • Jagged graphic in Canvas/Timeline
    Posted by Tim Coleman on July 23, 2013 at 11:36 am
    Frustrated with a graphic I’m using which keeps appearing jagged/not crisp on timeline.
    Sequence settings
    1280 x 720
    23.98FPS
    Apple ProRes 422 (LT)
    32-bit floating
    Pixel Aspect: Square
    Field Dom: None
    Other Text appears fine and when I load this graphic into the viewer it appears fine BUT when I place on timeline it’s jagged/un crisp. I’m viewing at 100%. Render settings appear consistent with other projects.
    Any help really appreciated!
    Rafael Amador replied 13 years, 1 month ago 2 Members · 1 Reply
  • Rafael Amador
    July 27, 2013 at 12:23 am
    If is a graphic, I understand it should be on a codec that supports Alpha channel.
    Prores only supports Alpha on Prores444. Prores LT do not support Alpha.
    rafael
