Activity › Forums › Media 100 › jagged edges on fonts of DVD
  • jagged edges on fonts of DVD
    Posted by Digitalgeorge on November 16, 2007 at 7:12 am
    I just finished a DVD project on DVD Studio Pro 2. The video came out looking alright. But the fonts have jagged edges. I use bitvice to compress to MPEG 2. What are the best settings to get rid of the jagged edges. When I exported from M100 I was saving the files as reference. Then in bit vice I would check off 10 bit and interlaced input. There are many other options but I’m not sure what to use for the best results. The fonts are moving across the screen and they look like a series of broken combs.
    Any help would be greatly appreciated.
    DigitalGeorge
    Floh Peters replied 18 years, 10 months ago 3 Members · 6 Replies
  • Floh Peters
    November 16, 2007 at 7:16 am
    Are you watching the result on a computer screen or a DVD player/CRT TV?You should monitor on a CRT TV monitor, since the edges you are seeing are most likely interlacing artifacts, which are expected when watching interlaced material on a progressive screen.
  • Digitalgeorge
    November 17, 2007 at 5:33 am
    I authored the DVD watching it on a computer screen. I burned the DVD and then saw the jagged edges on a television. I have a monitor set up for viewing media 100, but it’s not set up to monitor the DVD. What is the best way to compress the video on BitVice so I don’t get the jagged look?
    Thanks for the help Floh.
    DigitalGeorge
  • Floh Peters
    November 17, 2007 at 1:05 pm
    Are you using PAL or NTSC? You definitely have to turn on Interlaced Input (if your video is interlaced, which is very likely). And you have to select the right field order (Upper field first for PAL video). Plus, for NTSC you have to crop from 720*486 to 720*480, removing some lines from the top and bottom of the image. I am not really sure about the cropping and field order settings for NTSC, since e.g. cropping 3 lines would reverse the field order of your incoming signal. I would recommend doing some short tests for NTSC footage.
  • Gary Milligan
    November 17, 2007 at 6:38 pm
    [Floh] “Plus, for NTSC you have to crop from 720*486 to 720*480, removing some lines from the top and bottom of the image. I am not really sure about the cropping and field order settings for NTSC, since e.g. cropping 3 lines would reverse the field order of your incoming signal. I would recommend doing some short tests for NTSC footage”
    I may be wrong on this but I think when BitVice crops it takes 6 lines off the bottom – you can’t customize this setting – probably to avoid inadvertently reversing the field order.
  • Digitalgeorge
    November 18, 2007 at 1:28 am
    I am working in NTSC format. I did crop the video when asked for by BITVICE. I can’t remember if I chose the interlace option or not. But should i with NTSC? Do I also chose upper field first for NTSC? Thanks for the help.
    DigitalGeorge
  • Floh Peters
    November 18, 2007 at 9:27 am
    [DigitalGeorge] “I am working in NTSC format. I did crop the video when asked for by BITVICE. I can’t remember if I chose the interlace option or not. But should i with NTSC? Do I also chose upper field first for NTSC? Thanks for the help.
    You should select “Interlaced Input” when your source is interlaced (which is very likely). Media 100 NTSC 720 codec is Lower Field First, as far as I can remember (we are working in PAL, so I am not 100% sure about that).
