Activity Forums Avid Media Composer Jagged edges on background wall during AVID Speed changes–please help
  • Jagged edges on background wall during AVID Speed changes–please help
    Posted by Scotty Pupkin on April 22, 2005 at 2:55 am
    Hi
    I’m editing a commercial and ran into a problem. I increased the speed of a man dancing in his living room and the background wall–mainly on the edges and the “whites”–has a jagged edge to it–ONLY during the speed-ups at like 58 FPS… the jagged edges are sort of comparable to the edges on low res type…Does anyone know why this is? The footage is at 1:1 and I’m using an Avid Meridian Composer…
    Any help is greatly appreciated.
    thanks
    Tae replied 21 years, 4 months ago 3 Members · 2 Replies
  • Todd Beabout
    April 25, 2005 at 4:16 pm
    You have a few options as to how Avid handles frames. I believe it defaults to “Duplicated frames”. I usually use “Interpolate frames”, but you should experiment with a few of the settings and see if that helps your problem.
    -Todd Beabout
    Vazda Studios
  • Tae
    April 26, 2005 at 2:21 am
    If you have the option, promote the clip to Fluid Motion. It looks beautiful.
    -T
