Activity Forums Maxon Cinema 4D Jagged Edges around Alpha Material
  • Jagged Edges around Alpha Material
    Posted by Stephen Turcotte on July 12, 2012 at 4:28 am
    Im having trouble getting clean edges in my alpha channel under the materials setting. I’m trying to import a photo (outline of a person) but when I activate my alpha, a thin white line appears around the entire object. Both images are the same size and have completely smooth edges/ are high res.
    Anyone have an idea?
    Andre Yatsounski replied 9 years, 1 month ago 4 Members · 5 Replies
  • Adam Trachtenberg
    July 12, 2012 at 4:45 am
    Textures aren’t affected by geometry anti-aliasing, so you’ll have to use Best AA in render settings. Or if you’re already using it, you’ll have to increase the Min/Max settings.
  • Stephen Turcotte
    July 12, 2012 at 12:56 pm
    I have Best AA settings on and increased the Max setting to 16×16. The result was that the white line rendered very smoothly, but the line is still there. Is there a way to eliminate the outline completely?
  • Brian Jones
    July 12, 2012 at 2:35 pm
    is the image on a white background? It’s a very common problem, you have an image on a white background and take a selection from that to make an alpha but anti-aliasing in the image means you are really taking a bit of the white background as well so you get a white border.
    Either make the alpha a little tighter or change the background of the image to be black (or ideally the same color as the parts you want to see but that’s nearly impossible most of the time).
  • Stephen Turcotte
    July 12, 2012 at 4:09 pm
    Good point. It is on a white background, so I contracted the alpha just a bit and got pretty good results. Thanks for your help!
  • Andre Yatsounski
    August 12, 2017 at 5:13 pm
    You can do this one trick which can sometimes be a way, just go to alpha channel and tick (image alpha) if its not ticked, not sure if by default its ticked so this could be a reminder 😀
