Activity › Forums › Apple Final Cut Pro Legacy › jagged edges
jagged edges
Posted by Paul Waide on December 6, 2006 at 11:38 pmI’ve got a timeline in dvcpro50. whenever i try tu use the fcp filter basic 3d to shrink a clip and rotate it on the x or y axis the clip gets extremely jagged edges. Is this they way basic 3d works? or is there a bettter way to rotate x/y without jagged edges.
paul wChris Hall replied 19 years, 9 months ago 7 Members · 6 Replies -
David Roth weiss
December 7, 2006 at 12:57 am[apextv] ” Is this they way basic 3d works?”
Paul,
Unfortunately yes, its pretty useless in my experience. AE, Combustion, or possibly Boris are what you need for good quality animating in 3D space.
DRW
Tom Wolsky
December 7, 2006 at 1:31 amHave you tried using the anti-alias filter with this?
All the best,
Tom
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
Uli Plank
December 7, 2006 at 7:45 amCHV Electronics makes a set of plug-ins for FCP, including some better looking 3D-effects.
Regards,
Uli
Author of “DVDs gestalten und produzieren”, a book on professional DVD-authoring in German.
Lee Berger
December 7, 2006 at 12:13 pm -
Chris Hall
December 7, 2006 at 12:43 pmHi,
If you use a ‘mask shape’ filter before the basic 3D filter on the clip and use it to crop the image slightly by setting it to rectangle and using settings of 98 or 99 in the horizontal and vertical sliders, then it gets rid of the jagged edges. (you could then try adding a mask feather to smooth edges a bit more if necessary).
Chris
