Activity Forums Adobe After Effects Jagged diagonal lines
  • Jagged diagonal lines
    Posted by Marc Thomas on June 21, 2010 at 10:27 pm
    Hi, I’m working on D1/DV NTSC (o.9), 29.97 fps footage.
    From what I understand, AE de-interlaces my footage automatically… then I get aliasing (jagged lines) on diagonal lines.
    So my mission today was to find out how to avoid this “jagged line” problem.
    1) Is there a way to do this? What settings do I need to set?
    2) During my tests, I was exporting frames to compare my results and I got a BEAUTIFUL frame (ZERO jagged lines) that I exported after changing my composition settings to the “NTSC D1 Square Pixel” preset. But I was unable to duplicate my results. So I have no idea what else I changed besides the aspect ratio
    Any help/insight would be much appreciated 🙂
    Thanks in advance,
    Marc
    Marc Thomas replied 16 years, 3 months ago 34,333 Members · 1 Reply
  • Marc Thomas
    June 22, 2010 at 5:23 am
    I figured out that the exported frame with no jagged edges was produced by selecting “field render” >lower field first.
    So, is this what I’m supposed to do when I have interlaced footage that I want to export?…
    field render when exporting?
    If this is the case, I’m very surprised I haven’t read about this before as it seems like a pretty important piece of information.
    Marc
