Activity › Forums › Compression Techniques › Jagged Diagonal Lines
  • Jagged Diagonal Lines
    Posted by Scott Gray on February 16, 2007 at 10:08 pm
    I’m exhausted of running tests to try and produce a SD DVD that plays back a high resolution, static image with smooth diagonal lines in the image on an progressive scan display using a progressive scan DVD player. HELP!!! I’ve tried deinterlacing in FCP and every HQ progressive setting available in BitVice and Compressor 2. Every test looks the same, a roof line that is stair-stepping. Any ideas are greatly appreciated!
    Ben Waggoner replied 19 years, 7 months ago 2 Members · 1 Reply
  • Ben Waggoner
    February 18, 2007 at 7:58 am
    Can you post a screen shot of a frame showing the problem?
