Activity Forums Blackmagic Design j30sdi ?
  • Posted by Jason Levy on March 5, 2008 at 8:58 pm
    We have a project coming up where we will need to capture an extensive amount of PAL footage (but not master to PAL) and I was thinking of picking up a Sony J30SDI deck for use with our Decklink extreme.
    Anyone have experience with this deck? Is it a workable situation?
    jason
    Rob Alexander replied 18 years, 6 months ago 3 Members · 6 Replies
  • Jason Levy
    March 5, 2008 at 8:59 pm
    It’s a dual format NTSC/PAL deck, right?
  • Rob Alexander
    March 5, 2008 at 10:47 pm
    Over here in the UK they play both PAL and NTSC – you have to go into the menu, select the standard you want then switch it off and then on again.
  • Jason Porthouse
    March 6, 2008 at 10:06 am
    Hi Jason,
    Just completed a doc online where the 70+ tapes were recaptured using a J3. If you’re going SDI you don’t need a J30 (but it will work fine) if the J3 is cheaper – some rental places put a premium on the 30 as it has the firewire interface too. Oh, just a thought – maybe the J3 doesn’t do audio via SDI – might be worth checking.
    Deck control wasn’t a problem, though it is crude compared to the 500. For digitising it’s fine though.
    One gotcha we had (this is using a multibridge pro) was digitising 16 channels of audio (14 of which were blank) because Doofus here forgot to turn the other 14 off for the first reel. Oh well.
    HTH
    Jason
    _________________________________
    Before you criticise a man, walk a mile in his shoes.
    Then when you do criticise him, you’ll be a mile away. And have his shoes.
    *the artist formally known as Jaymags*
  • Jason Levy
    March 6, 2008 at 3:30 pm
    Thanks for that info. Yeah I’ve had the 16 track capture experience…
    They don’t seem to offer the J3 any more as a new purchase, just the j30 but I do see some used ones floating around.
    Thanks.
    jason
  • Jason Levy
    thanks Rob.
  • Rob Alexander
    March 6, 2008 at 3:45 pm
    No problem. The J3 does do audio over SDI by the way – I know ‘cos I’ve got one! 🙂
