Activity › Forums › Creative Community Conversations › iZotope RX8 Removes Direct FCPX Plug-In Support
Oliver Peters replied 6 years ago 7 Members · 15 Replies
Craig Seeman
September 14, 2020 at 9:56 pmThanks for that. Have you tested to see if they work and without clipping off the end of the audio?
See this old COW thread
https://creativecow.net/forums/thread/izotope-rx5-in-fcpx-cuts-off-end-of-audio/
iZotope had said this was an FCPX issue and they could/would not fix it.
James Culbertson
September 16, 2020 at 6:58 pmDe-Clip still has the clipping off of the audio at the end. Not sure which of the others has this issue. I primarily use RX8 Voice De-noise which does not have this issue in RX8 (or RX7).
Tony West
September 17, 2020 at 7:43 pmI’m running RX8 also and no problems here with the FCP X plugins.
Oliver Peters
September 18, 2020 at 3:45 pmTo my knowledge the RX8 plug-ins work. It’s the RX Connect plug-in that doesn’t. This would normally provide a method to send a track or clip from the timeline directly to the RX8 application and then back. iZotope’s instructions are to do it manually.
