Activity Forums Apple Final Cut Pro Legacy iWork Keynote and Final Cut Pro – work together???
  • iWork Keynote and Final Cut Pro – work together???
    Posted by Anna Little on May 14, 2009 at 4:30 am
    Can someone give me some advice please.
    I’ve been asked to produce a short video, with narration, using (moving) slides from iWork Keynote 2009 (like powerpoint apparently). Can these images be transferred to Final Cut Pro 5.1.4. so I can add the narration to the video??
    I don’t know how else to lay audio underneath the slides…..
    Any advice very welcome, thanks.
    Anna
    Anna Little
    Ernie Santella replied 16 years, 10 months ago 7 Members · 13 Replies
  • 13 Replies
  • Ernie Santella
    May 14, 2009 at 4:34 am
    You can export a Quicktime movie out of Keynote. Just import that into FCP and add sound.
    Ernie Santella
    Santella Productions Inc.
    http://www.santellaproductions.com
  • Anna Little
    May 14, 2009 at 4:41 am
    Lovely, thanks for the quick response Ernie! Really helpful.
    Anna Little
  • Ernie Santella
    May 14, 2009 at 4:43 am
    You’re welcome. Keynote is awesome, because it will also allow you to import a Power-point file and export it as a QT WITH the transitions intact! That’s what sold me on Keynote.
    Ernie Santella
  • Anna Little
    May 14, 2009 at 5:18 am
    Very interesting! Thanks.
    Anna
    Anna Little
  • David Bogie
    May 14, 2009 at 4:43 pm
    Warning: Just because the slides can be exported as QT does not mean they’ll look good as video.
    My experience with moving PP to video is that almost every slide has to be rebuilt from scratch. Two reasons: The person who created the PP is an idiot and the resolution of video is fixed whereas the rez of the PP/Keynote is variable.
    bogiesan
  • Anna Little
    May 14, 2009 at 6:11 pm
    Thanks.
    What’s the alternative/answer!?!
    I have to get a video ready asap for an important audience!!
    Anna Little
  • Ernie Santella
    May 14, 2009 at 6:15 pm
    1st, let the person know who’s authoring the PP that they need to think TV instead of computer/projection. Here’s some guidelines:
    – Larger fonts and less on each page.
    – Keep everything inside a safe title area (Not too close to the edges of the frame)
    – Build all slides in a 4:3 or 16:9 size.
    – Use contrasting colors for type and background (No Red on a Green Background)
    That’s a start. You can always take the movie you export and mortise it back a bit in FCP to be in safe Title area. That works if the fonts aren’t too small.
    I agree with David. You may have to rebuild some slides if they are unreadable. Just instruct the authors to think TV frame.
    Ernie Santella
  • Anna Little
    May 15, 2009 at 2:22 am
    Thanks for all of that info. Only problem is – it’s me designing the slides and I’m using Keynote for the first time!! I was told I’d be editing it all on FCP – but when I arrived, it was all on Keynote. My deadline is Monday so I hope to resolve any issues….but basically I should be able to export moving slides in Keynote to FCP right? I tested a couple and they looked ok….but there are 18 so who knows what can happen!!
    Thanks again.
    Anna Little
  • Ken Jones
    May 15, 2009 at 3:36 pm
    Don’t use thin, horizontal lines.
    I will open an existing PPT presentation and bump the lines up from 1 pixel to 5 or 6 pixels.
  • Von Thomas
    June 9, 2009 at 4:44 pm
    I’m very new to FCP, and I come from the still side of town. I’d like to know when brining a Keynote into FCP, how do I set it up. In Easy Setup what is the “Format” and what should the “Use” be?
    Also, I have the same question for RED files being imported into FCP, but I’ll direct that question to the RED thread.
    Von
    Von Thomas
