Activity › Forums › Adobe Premiere Pro › I’ve tried everything – Avi’s with DivX, Xvid video and Dolby AC3 audio codecs that play without audio
  • I’ve tried everything – Avi’s with DivX, Xvid video and Dolby AC3 audio codecs that play without audio
    Posted by Cory Andrews on February 8, 2016 at 5:43 am
    I’ve tried transcoding with MPEGStreamClip, Squeeze, Adobe Media Encoder, Handbrake, DivX Converter, Compressor. These files will not play in Quicktime despite updating my version of Divx, my AC3 codec, my XVIDDelegate.component file, and Perian. They will not play in the Divx player either. They all play in VLC, but that doesn’t help me edit them in Premiere or FCP, both of which play the video, but without sound. I’m considering just recording the audio with software that records my computer’s audio out channel and linking it in my editing software, but this seems a little ridiculous. Is there something I’m still missing here?
    I’ve tried converting these files to Apple Pro Res 422 Proxy (MPEG Streamclip and Compressor), MP4 H.264 (Handbrake), MKV H.264 (DivX Converter), NTSC DV (Adobe Media Converter).
    Here is the Media Inspector info for one of the files I’m trying to convert:
    General
    Complete name : /Volumes/Film Work/Beavertown.avi
    Format : AVI
    Format/Info : Audio Video Interleave
    File size : 896 MiB
    Duration : 1h 28mn
    Overall bit rate : 1 412 Kbps
    Writing application : VirtualDubMod 1.5.4.1 (build 2178/release)
    Writing library : VirtualDubMod build 2178/release
    Video
    Format : MPEG-4 Visual
    Format profile : Advanced Simple@L5
    Format settings, BVOP : 1
    Format settings, QPel : No
    Format settings, GMC : No warppoints
    Format settings, Matrix : Custom
    Codec ID : XVID
    Codec ID/Hint : XviD
    Duration : 1h 28mn
    Bit rate : 1 181 Kbps
    Width : 464 pixels
    Height : 320 pixels
    Display aspect ratio : 3:2
    Frame rate : 25.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.318
    Stream size : 750 MiB (84%)
    Writing library : XviD 1.2.0.dev47 (UTC 2006-11-01)
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Mode extension : CM (complete main)
    Format settings, Endianness : Big
    Codec ID : 2000
    Duration : 1h 28mn
    Bit rate mode : Constant
    Bit rate : 224 Kbps
    Channel(s) : 2 channels
    Channel positions : Front: L R
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Stream size : 142 MiB (16%)
    Alignment : Split accross interleaves
    Interleave, duration : 96 ms (2.40 video frames)
    Interleave, preload duration : 96 ms
    Language : English
    Any help is greatly appreciated!
    Chris Walsh replied 10 years, 7 months ago 4 Members · 7 Replies
  • 7 Replies
  • Chris Wright
    February 8, 2016 at 11:44 am
    your problem isn’t the video codec, you need a directshow audio filter for ac-3 which is used in some dvd’s DTS decoding.
    try this one. I’ve used it before and it’s free.
    https://sourceforge.net/projects/ac3filter/
    https://www.ac3filter.net/wiki/AC3Filter
  • Cory Andrews
    February 10, 2016 at 3:00 am
    Hey Chris,
    Thanks for writing back. I actually have a Mac, so I can’t download that.
    However, I did download AC3 decompressor component that came up in Google?
    https://qt-ac3-codec.en.softonic.com/mac
    I also have Perian installed, which is supposed to have AC3 support?
    Any other ideas?
    Thank a lot,
    Alex
  • Tero Ahlfors
    February 10, 2016 at 5:11 am
    [Cory Andrews] “Any other ideas?”
    Use formats that are supported by Premiere.
  • Cory Andrews
    February 10, 2016 at 5:28 am
    I’m trying to make an essay film and I am using video from a variety of different sources. I have no other access to some of my material than through DivX AVIs. If someone can offer some advice, it would be greatly appreciated.
  • Cory Andrews
    February 11, 2016 at 3:44 am
    Come on, really? Is that final completely unhelpful, snarky response all I get? Am I being blackballed here because I’m using DivX files? I’m trying to quote a text. An author can quote another author to make a point, a filmmaker is legally allowed to quote another filmmaker to make his point, I need to quote a DivX file of film, I was told Final Cut was no bueno, I was told Premier could handle anything, was I wrong?
    I put a file named AC3 Codec.component in my library/Quicktime folder, I have Perian, do I need to do something more than that?
  • Chris Wright
    February 11, 2016 at 1:00 pm
  • Chris Walsh
    February 11, 2016 at 7:21 pm
    Easiest and fastest thing would be to find someone with a Windows PC and convert to Quicktime, MP4, or MPEG2 there using MPEG streamclip. I’ve come across many different DivX files that I could never get converted on my macs, so ended up converting on a PC and copying across.
    Depending on how large the files are you may want to try a few of the online conversion sites if there’s no PC available.
    Chris Walsh
    http://www.musicfog.com
    Silver Spring, MD
    Premiere Pro CC, FC7 & AVID
    Former Windows diehard and edit*or
