Activity › Forums › Maxon Cinema 4D › I’ve somehow managed to set a permanent “pivot point” in my perspective window R13
  • I’ve somehow managed to set a permanent “pivot point” in my perspective window R13
    Posted by Ryan Paterson on October 9, 2012 at 11:19 pm
    The dynamic “click-based” pivoting was working just great but I’ve somehow managed to make it stick… ie) the little ‘+’ cursor that denotes where you’re pivoting around is just stuck in space rather than changing posiiton whenever I click..
    I must’ve hit a weird key or something, can someone give me a hand please?
    Ryan Paterson replied 13 years, 11 months ago 2 Members · 2 Replies
  • Darby Edelen
    October 10, 2012 at 12:13 am
    It looks like the “Insert” key may be the issue.
    I found this with the handy dandy “Customize Commands…” menu option under the Window > Customization menu. This is usually only helpful if you know the name of the command, I lucked out when I filtered for “Pivot.”
    Darby Edelen
  • Ryan Paterson
    October 10, 2012 at 12:29 am
    Very handy screen indeed! Thank you
