Activity › Forums › VEGAS Pro › I’ve been at this for days-weeks. terrible Youtube video quality. Dxtory+Vegas Pro 13
  • I’ve been at this for days-weeks. terrible Youtube video quality. Dxtory+Vegas Pro 13
    Posted by Sean Toombs revz on June 16, 2014 at 9:33 am
    For the life of me I can’t figure out how to upload a video to YouTube without it coming out really pixelated. I have tried the highest bit-rate and every render preset and custom preset in Vegas to no avail.
    Every single render from Vegas looks fantastic to me, it’s when it’s uploaded to Youtube, the video is terrible.
    I have searched dozens of forums that talk about the issue, trial and error, and the solution is never posted, or the forum ends short.
    I use Dxtory with the Lagarith Lossless Codec,with YV12
    It outputs an AVI file.
    1920×1080 30fps PCM Audio codec PCM 192000Hz, 24bit stereo
    Data rate: 1,990,656kbps – Total bitrate 1995264kbps
    Lagarith Lossless codec has been the only codec on this computer.
    Again, the rendered video itself from Vegas has always been fantastic, but the Youtube video is just terrible. Dxtory and Vegas is being used by most of the big channel Youtubers and does have a great looking end result.
    I’m now thinking a capture card would fix this.
    I’ve kept the resolution, frames a second, and screen aspect ratio the same in the render settings.
    Here’s what I’m ending up with:
    https://www.youtube.com/watch?v=U1-iq8bdT_k
    https://www.youtube.com/watch?v=9xcSc2Agqq0
    https://www.youtube.com/watch?v=oFVOiMZ5Kk8
    Thank you.
    -Sean
    Norman Black replied 12 years, 3 months ago 3 Members · 2 Replies
  • Steve Rhoden
    June 16, 2014 at 2:54 pm
    This issue is getting quite tiresome to hear. Your issue is with
    what Youtube is doing with your content. From your renders out
    of Vegas is clean and pristine, that’s the important thing. There
    is nothing more you can do.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-461-9019
  • Norman Black
    June 16, 2014 at 4:25 pm
    [Sean Toombs ReVz] “Again, the rendered video itself from Vegas has always been fantastic, but the Youtube video is just terrible. “
    Youtube re-encodes EVERYTHING you upload to them. If you do not like their result there is nothing you can do in Vegas to get Youtube to give you a better Youtube result. You just waste your time uploading higher quality video streams than necessary.
    Speed of movement and high frequency detail are always problems with Youtube/Vimeo encodes. Their encodes are low bitrate.
    The only things you need to do are make sure your upload file is 30fps or lower since your game capture source is likely well above 30. Make sure resampling is OFF since your are changing frame rates on high motion sources.
