Activity › Forums › Adobe After Effects Expressions › iTunes effect
iTunes effect
Posted by Scott Hill on June 28, 2007 at 3:07 pmNew to expressions, though I’ve used AE for quite some time. I’m wondering how difficult it would be to create the effect like the iTunes ‘flip through albums.’
I’d like to take a few dozen video clips, line them up, kind of like a deck of cards, and flip through them, pausing slightly as each comes center stage.
Has anyone done this, or is there a tutorial that might step me through this sort of effect?Thanks kindly
Ben Jones replied 18 years, 1 month ago 4 Members · 9 Replies -
Filip Vandueren
June 28, 2007 at 6:57 pmYou’l find some great discussion and some project files in this very forum if you’ll do a search for it !
Scott Hill
June 29, 2007 at 9:00 pmHere’s a link to what I’m trying to copy for a sports highlight video.
https://www.apple.com/itunes/jukebox/coverflow.html
Filip Vandueren
June 30, 2007 at 12:23 pmhere’s the thread where this has been recreated:
https://forums.creativecow.net/readpost/227/7142?univpostid=7127&pview=t
you can even find a link to an after effects project there.
Scott Hill
July 1, 2007 at 3:10 amThank you. This is great. I guess I didn’t search the right terms.
Again, thanks. -
David Gerberding
July 16, 2007 at 11:35 pmI have the AE project called itunes_browser. For someone who doesn’t know expressions, can anyone explain how to control the movement of the “albums”? I’ve tried the slider, with no luck.
Scott Hill
July 17, 2007 at 2:23 pmI used the Itunes_browser project as a starting point for a 10 minutes piece. The slider worked great. I don’t know much about expressions, but was able to create many more layers, copying the expression and adjusting some of the parameters so the new layers moved in relation to the others.
By sliding the slider left or right, it controlled each layer. I replaced the solid in each layer with footage. I don’t know what else to tell you about the slider. I just dragged it and created keyframes. Eased the keyframes. Worked like any other keyframeable item, like position or scale.I’ll make my project into an mp4 later today and post it. It turned out great.
David Gerberding
July 18, 2007 at 12:09 amThanks Scott. I downloaded the raw ae file again today and it worked fine. I have not converted it to NTSC yet…, nor the frames per second…that may be what broke everything yesterday! Any advise for how to do that properly?
Maybe I should create a new NTSC comp, drop the “reflections” into it and render from there. Sound good?
Scott Hill
July 18, 2007 at 2:40 pmI just went into each of the compositions’ settings and changed it to NTSC 29.97. I thought it might mess it up a bit, but it worked just fine.
Ben Jones
August 8, 2008 at 9:31 pmhey guys i would love a copy of this itunes file. im trying to do the same thing and now for music videos and id love as much help as possible
thanks
