Activity Forums Adobe After Effects iTunes Commercial
  • Austin Killey
    June 7, 2008 at 4:46 pm
    It seems like particle effects from Trapcode Particular. Otherwise it could be pre-matted smoke effects, like the ones Andrew Kramer uses in his Riot Gear package. Otherwise if you’re looking at the swipes that the band members make when moving around, that too is Trapcode Particular at play. Andrew Kramer again is the man with this one, teaching you how to achieve that effect:
    https://www.videocopilot.net/tutorials.html?id=34
