Activity Forums Adobe Premiere Pro It’s probably staring me in face but….
  • It’s probably staring me in face but….
    Posted by Steve Martin on April 23, 2013 at 9:09 pm
    OK, I’ve been editing for almost 2 days straight, I’m bleary eyed and am still relatively new to Premiere Pro. My brain has hit the brick wall….
    I’ve got a bunch of raw footage clips in a bin and want to export all of them and maintain file names and time code. Surely there’s way to do that, right. I just can’t find it.
    Yea, I know… don’t call me Shirley!
    I’ll be napping on the edit suite couch while I await one of you kind souls to rescue me.
    ZZZzzzzzz………..
    Steve
    Production is fun – but lets not forget: Nobody ever died on the video table!
    Steve Martin replied 13 years, 5 months ago 3 Members · 6 Replies
  • Angelo Lorenzo
    April 23, 2013 at 9:17 pm
    Open Adobe Media Encoder, drag original files onto the Window, apply preset and export.
    If you don’t try to save the files in the same folder, they’ll maintain the same file name.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Can your post production question fit in a tweet? Follow me on Twitter
  • Steve Martin
    April 23, 2013 at 9:38 pm
    Brilliant Angelo – you rock!
    One more question from the brain dead if you don’t mind. I’ve got something like 200 hundred clips. When I drag them into Media Encoder, it defaults the output file to the same location as the source. Is there a way to change the output files to go to a folder I define – without doing each file individually?
    Steve
  • Angelo Lorenzo
    April 23, 2013 at 9:43 pm
    Edit > Preferences > General. Last setting will be a checkbox for default export location, select it and select a path. You should be set.
    Angelo Lorenzo
  • Steve Martin
    April 23, 2013 at 9:46 pm
    You Da Man!
    Thanks so much
  • Tero Ahlfors
    April 24, 2013 at 4:46 am
    You might also try using Prelude.
  • Steve Martin
    April 25, 2013 at 4:41 pm
    Thanks Tero,
    I haven’t tried Prelude yet, but will download and give it a go… just to play with an alternative. I’ve heard some limited (but good) things about Prelude. I take it you like the app and find it useful? How well does it fit into your workflow?
    Best,
    Steve
