Activity Forums Adobe Premiere Pro Its possible to import PSD with smart object into Adobe Premiere?
  • Its possible to import PSD with smart object into Adobe Premiere?
    Posted by Petr Berger on August 16, 2011 at 4:50 pm
    Its possible to import PSD with smart object into Adobe Premiere? (or AE or Media Encoder?) I’m doing some adjustments to video clips in Photoshop with plugins from Alien Skin (which are only for Photoshop). You have to convert the video clips to a smart object, otherwise it will not work. The problem is rendering in Photoshop is very slow and I have to render my project twice. Is there a solution for this?
    Petr Berger replied 15 years, 1 month ago 2 Members · 4 Replies
  • Todd Kopriva
    August 17, 2011 at 12:56 am
    Import the PSDs into After Effects.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Petr Berger
    August 17, 2011 at 3:24 pm
    Thanks. Does it work even when I use plugins (from Alien Skin) in Photoshop that are not designated for AE? I tried to import such PSD file, but I dont see the applied effects (AE says there are missing filters). Maybe it cant be done or maybe I’m doing something wrong…
  • Todd Kopriva
    August 17, 2011 at 4:18 pm
    No, After Effects doesn’t understand third-party Photoshop filters. If you need to use the results of those, save out a flattened image file.
  • Petr Berger
    August 17, 2011 at 4:51 pm
    When I use flatten image on the video file, the result is just one frame, not the whole video.
