Activity › Forums › Boris FX Particle Illusion › it is posible to eliminate trasparency for my own texture
  • Francois Blawat
    July 12, 2016 at 2:34 pm
    [luis herzz]
    I’m no expert, but try using an Image file that does not have transparency and see if that works. JPG or BMP perhaps. Can you try that to see if that works. You never mentioned what format your texture was saved in to begin with.
    FixitMad
  • Francois Blawat
    July 12, 2016 at 9:37 pm
    [luis herzz]
    I just took a look at your image that you attached a bit closer this time. Try unchecking the Intense to see if that helps at all. You never mentioned what editor you used to create your image.
    FixitMad
  • Luis Herzz
    July 13, 2016 at 4:18 pm
    i was using png, with jpg works fine thx
