Activity › Forums › Apple Final Cut Pro Legacy › iStopMotion Troubles – Does anyone have experience with this?
  • iStopMotion Troubles – Does anyone have experience with this?
    Posted by Patrick on June 8, 2005 at 3:39 pm
    If anyone has any additional thoughts or experience using iStopMotion, I would be very grateful to hear your thoughts. Attached below is the thread thus far.
    Date: Jun 7, 2005 at 11:03 am
    Subject: Anyone use istopmotion? We have a problem…….
    We’re using istopmotion to do some stop motion capture (obviously), and we’re having major capture issues between the camera and the laptop – G4 latop (Tiger OS). The problem lies in the device recognition of the Canon G6 camera. The process will start off okay (some of the time), but inevitably, istopmotion says that it cannot recognize the device.
    Any thoughts or advice would be greatly appreciated.
    Patrick
    Reply To This Post
    Post 2 of 3
    Date: Jun 7, 2005 at 1:17 pm
    Subject: Re: Anyone use istopmotion? We have a problem…….
    Is this recent?
    Did it work a few days ago?
    Canons are notorious around here for Firewire issues so are you certain it’s on the mfr’s list of approved input sources?
    Is there an auto-power saving protocol running on the camera that might be causing it to drop the connection?
    bogiesan
    Reply To This Post View Parent Post
    Post 3 of 3
    Date: Jun 7, 2005 at 3:00 pm
    Thanks for responding! Per your questions…….
    It was working fine recently (the last week has been fine), but then suddenly developed these problems.
    Also, the connection is a USB. I’m not sure if that would cause any problems.
    As for a powerdown, protocol. The on-camera LCD does shut off after a time. But that function wasn’t causing any problems before.
    Any additional thoughts? Thanks,
    Patrick
    Patrick replied 21 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
