Activity › Forums › Avid Media Composer › ist there a way to iMPORT .srt files in Avid?
  • ist there a way to iMPORT .srt files in Avid?
    Posted by Bilbo Calvez on June 19, 2016 at 1:13 pm
    Hi dear people,
    ist there a way to iMPORT .srt in Avid?
    Directly it doesn’t work, but what could be a work around?
    Thanks a lot!
    Bilbo
    Pat Horridge replied 10 years, 3 months ago 2 Members · 5 Replies
  • Pat Horridge
    June 20, 2016 at 8:50 am
    Yes via the subcaps effect.
    Pat Horridge
    Broadcast & Post Consultant, Trainer, Avid Certified Instructor
    Free online Tutorials at VET digital media academy online https://vimeo.com/channels/752951
    pat@vet.co.uk
  • Bilbo Calvez
    June 20, 2016 at 11:38 am
    Thanks dear Pat.
    So I tried.
    I export my .srt file again as a .stl (in Aegisub)
    In MC I put on a SubCap Effect. Wrote anything to prepare the lay-out. Then import the .stl file.
    – The lay-out didn’t apply
    – I only import 8 Minutes of subtitles (96 titles). The movie is 1hour 15…
    I tried a few times more, and another sequence and so on. Always this 96 titles limitation. Do you have an idea how to handle this issue?
    Dear Greetings, Bilbo
  • Pat Horridge
    June 20, 2016 at 11:48 am
    You will probably find an error in the source file around the 96 caption position. The subcap effect is picky and needs everything to be correct.
    I’d normally do the subcaps in 3 or more chunks to make it easier to track issues.
    Look at the file in a text editor and you should be able to spot an extra carriage return or something else unexpected.
    Pat Horridge
    pat@vet.co.uk
  • Bilbo Calvez
    June 20, 2016 at 2:49 pm
    Thanks dear Pat,
    actually I found nothing special, but I’m gonna try the trick to divide it in smaller segments.
    Greets from Berlin!
  • Pat Horridge
    June 20, 2016 at 3:04 pm
    You will find something wrong. Don’t forget some characters can’t be displayed but are present.
    The subscap effect requirements are simple but also inflexible. I’ve had many occasions when the imported titles aren’t complete and its always a tiny error in the source file.
    Pat Horridge
    pat@vet.co.uk
