Issues with Track Mattes – Luma matte makes everything B/N
Hello everyone,
I’m having some trouble using a luma matte. I used C4D to make cube spinning transition and rendered some object buffer pases as 8 bit TIFF sequences to use as luma matte in AE.
So now in AE, I have my animation all setup made with precomps with some Illustrator art inside them with continuous rasterization. But the moment I put the TIFF sequence below the Precomp and select Luma Matte the precomp contents turn to black and white. The Luma Matte is doing its job for the transition, but turns everything to black and white. This has never happened before.
Here’s what I’ve tried to fix this at the moment without any luck:
– I thought maybe it was because the AE project was in 32 bits an the tiffs were 8 bit. So I dropped the project to 8 bit and also rendered the TIFF in 32 bit and used the 32 bit project.
– I prerendered the TIFF sequence as a .mov with RGB only in animation and used it as the luma matte.
– I prerendered the precomps, then used both the tiff sequence and the prerendered as .mov tiff sequence as the luma matte.
– I made the AE project anew.
– I rendered the cube spinning transition as a PSD sequence rather than TIFF.
– I’ve looked into all the comp and precomps settings.
– I’ve checked all the transfer modes inside the precomps.Any help would be greatly appreciated. I just can’t find what’s going wrong and I’m starting to get worried about my project’s deadline.
Thnx,
D.
