Activity Forums Apple Final Cut Pro Legacy Issues with the AJA io HD
  • Issues with the AJA io HD
    Posted by Thomas Frank on March 17, 2009 at 9:37 am
    We are having this issue on all our edit stations.
    The configuration is:
    Final Cut Studio 2 (up to date)
    Mac Pro
    Dual 30″ Cinema
    AJA io HD
    Panasonic DVCPRO HD AJ-HD 1400 Deck
    When we have both the AJA box and the Panasonic up running (Firewire)
    Final Cut Pro ether crashes on the startup or when pulling up the Capture window.
    Also Final Cut Pro is really slow when it does not crash.
    We have noticed if you power one of the devices down FCP runs fine.
    AJA couldn’t help us on this issue maybe somebody her had the same problem??
    Right now I am going to replace the AJA boxes with Krona cards to see if that fixes the issue.
    Thomas Frank replied 17 years, 4 months ago 4 Members · 10 Replies
  • 10 Replies
  • Rafael Amador
    March 17, 2009 at 10:58 am
    The ioHD need a full FW800 bus for working.
    You can not plug any other FW device in the same bus.
    I don’t know your Mac Pro how many buses have.
    Think that two FW connexion doesn’t means two FW buses.
    I think that installing a FW800 card should work.
    Rafael
    http://www.nagavideo.com
    (and here some clips for the friends: https://www.vimeo.com/2694745 )
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Walter Biscardi
    March 17, 2009 at 11:56 am
    [Andree Franks] “We have noticed if you power one of the devices down FCP runs fine.
    Correct. You cannot have two video devices connected to FCP via Firewire at the same time. Both the Panny and the AJA Io HD are Firewire Video Devices.
    The 1400 should be connected via RS-422 and SDI to the IoHD for digitizing and layback to tape.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Thomas Frank
    March 19, 2009 at 7:35 am
    Thanks for the quick reply!
    Final Cut Pro should have no issues talking to the deck over RS-422, right?
    I am not even sure if we really have a need for the ioHD at the moment…
    We receive all our footage over miniDV (at the moment) or over a media server.
    Maybe if somebody has a chance they can describe me what I can do with the AJA ioHD except for importing and exporting HD and SD formats material over Firewire port… …or compared to a capture card.
    I am more a Black Magic guy :o)
    P.S. Walter could I get in touch with you about configuring and building edit stations?
  • Walter Biscardi
    March 19, 2009 at 12:50 pm
    [Andree Franks] “Final Cut Pro should have no issues talking to the deck over RS-422, right? “
    No, that’s the best way to drive the 1400.
    [Andree Franks] “Maybe if somebody has a chance they can describe me what I can do with the AJA ioHD except for importing and exporting HD and SD formats material over Firewire port… …or compared to a capture card.
    I am more a Black Magic guy :o) “
    It does everything the AJA Kona 3 does except for uncompressed HD. It’s essentially a capture card in an external box. Upconversion, cross conversion, down conversion, capture to ProRes via the box instead of processors, etc… http://www.aja.com and look at the Io HD specs. It’s all there.
    Read my Blog!
  • Thomas Frank
    March 26, 2009 at 2:00 pm
    Hey okay we have them talking now! :o)
    But for some reason we can’t get the Capture format right.
    There is a black border around the NTSC DV footage and the SDI 1 input signal is showing 1080i 29.97 (playing is NTSC DV).
    in FCP we have the Device set to AJA IoHD 59.94 DVCPro Panasonic VTR
    Capture AJA IoHD 529 29.97 DV (With a black border around it)
    any other format will show a distorted image.
    Oh yeah it shows up like that in the FCP capture screen as well in on our output Monitor.
    Shouldn’t the AJA recognize the incoming signal or change the format?
  • Gary Adcock
    March 26, 2009 at 7:03 pm
    [Andree Franks] “Shouldn’t the AJA recognize the incoming signal or change the format?
    It does – look in the IoHD control panel the inbound signal is on the left
    – FCP is not smart enough to change any external device.
    “But for some reason we can’t get the Capture format right.”
    the capture format should be set using an EASY SETUP.
    it should say something AJA IoHD 525 29.97 ProRes HQ. ( or whatever your capture format should be)
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
  • Thomas Frank
    March 26, 2009 at 7:25 pm
    hey thanks, we had final cut pro ussing every format there is.
    Also in the aja control panel (input tab) we can’t find a option to change the SDI 1 input from 1080 to something else.
  • Gary Adcock
    March 26, 2009 at 9:06 pm
    [Andree Franks] “Also in the aja control panel (input tab) we can’t find a option to change the SDI 1 input from 1080 to something else.”
    You can’t- that input is showing you what the incoming video signal is you would have to change that at the source to have it be something different.
    To change the input from SDI1 to anything else – click on any input and hold down the right mouse button or the control key to be able to change to any other input (analog, HDMI SDI2)
    gary adcock
    Studio37
  • Thomas Frank
    March 26, 2009 at 9:25 pm
    Gary thanks for the quick responce!
    Yeah that is what I meant the should recognize the NTSC footage from the Panasonic Deck.
    Her is the funny thing, we have two edit stations with the same setup.
    On the other it works fine with the same miniDV tape???
  • Thomas Frank
    March 27, 2009 at 2:15 pm
    HA, found the issue! The cables where not connected correctly!!
    Thank you to every help!
