Activity Forums Apple Final Cut Pro Legacy Issues with the ai13 Codec in Final Cut Pro 6 and Quick Time
  • Issues with the ai13 Codec in Final Cut Pro 6 and Quick Time
    Posted by Amy Lafleche on August 30, 2012 at 3:07 pm
    I imported a timeline from Final Cut 7 to my Final Cut 6 using XML files.
    I reconnected all the media except for one file which uses the ai13 codec. When I try to render the timeline I’m getting an error that says the Codec could not be found.
    I installed the AVC Intra Decoder v1.5 and get the same error.
    I also tried opening the raw file in Quick Time and got a similar error.
    Here are the two screenshots with errors:
    Suggestions? Any help would be appreciated.
    Steve Eisen replied 14 years ago 4 Members · 3 Replies
  • Rafael Amador
    August 30, 2012 at 3:37 pm
    I haven’t found nothing about that codec in Google.
    Try to open the file with VLC and see what happens.
    rafael
    http://www.nagavideo.com
  • Anna Ingenthron
    August 31, 2012 at 12:14 am
    I believe this is an AVC-Intra codec. You’d have to use Log and Transfer if you have the P2 plug-in to bring it into the project. Not sure if you need to recreate a folder structure for the file.
  • Steve Eisen
    August 31, 2012 at 3:11 am
    I can not guarantee that it will work in FCP 6.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Creative Pro Users Group
