Activity Forums Adobe After Effects Issues with Roto Brushing a clip that’s split into sections
  • Issues with Roto Brushing a clip that’s split into sections
    Posted by Luke Anderson on October 17, 2024 at 1:05 pm
    I’m working on rotoscoping a 6-second 1080p video. To optimize performance and avoid triggering propagation at the start of the clip when making adjustments, I’ve been splitting the video into 37-frame sections.
    However, I’m running into a couple of issues with this workflow:
    1. Propagation Issues in Split Sections: After rotobrushing the first section and splitting the video (Shift + Ctrl + D), the last frame’s Roto Brush from the first section appears in the second section. However, propagation still starts from frame 0 in the new section. If I delete the strokes in the second section to stop propagation, it also removes the necessary Roto Brush data, making it impossible to align the two sections properly.
    2. Roto Brush Misalignment Between Sections: In order to remedy #1, I have tried adding a new rotobrush modifier to each section, however, since each section has its own Roto Brush calculation, the brushes don’t align seamlessly between sections, causing a noticeable jump when playing through the clips.
    Has anyone encountered this problem, and if so, do you know how to keep the sections aligned?
    Per Scaffidi replied 1 year, 6 months ago 2 Members · 1 Reply
  • Per Scaffidi
    February 23, 2025 at 7:04 pm
    This is a late response, but:
    The answer to #1 is to drop your shot into shutter encoder, select “Cut without re-encoding”, and then in the bottom right change it to “split” and set it for every 10-seconds or whatever you need.
    I’m encountering the same issue as #2 and wondering if anyone has a solution? I am rotoscoping a 4-minute long clip. I’ve split up the shot into 20-second clips which my system can handle at a decent pace, but at some of the breaks, the roto doesn’t quite match up.
