Activity › Forums › Apple Final Cut Pro Legacy › Issues with rendering
  • Issues with rendering
    Posted by Anthony Jefferson on February 1, 2011 at 7:27 pm
    I am making some tweaks to an old project but every time I try to render anything it gives me the Error: Out of Memory message. I have all my projects on external hard drives and I tried clearing out space on the drive the project is on there are currently 12 available gigs. I even tried switching over the rendering to another drive but it didn’t work. I am only getting this issue with this particular project. Any suggestions?
    Jerry Hofmann replied 15 years, 8 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    February 1, 2011 at 11:53 pm
    There is likely some media there that FCP doesn’t like. The memory error isn’t drive problems, it’s RAM problems.
    Blank Layers in Photoshop files imported to FCP can cause this for example.
    What is the format of the sequence you’re working with, and what are the properties of the source clips?
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
